The CY7C1021 is a high-performance CMOS static RAM or-
ganized as 65,536 words by 16 bits. This device has an auto-
matic power-down feature that significantly reduces power
consumption when deselected.
Writing to the device is accomplished by taking chip enable
(CE) and write enable (WE) inputs LOW. If byte low enable
(BLE) is LOW, then data from I/O pins (I/O1 through I/O8), is
written into the location specified on the address pins (A0
through A15). If byte high enable (BHE) is LOW, then data from
I/O pins (I/O9 through I/O16) is written into the location speci-
fied on the address pins (A0 through A15).
Reading from the device is accomplished by taking chip en-
able (CE) and output enable (OE) LOW while forcing the write
enable (WE) HIGH. If byte low enable (BLE) is LOW, then data
from the memory location specified by the address pins will
appear on I/O1 to I/O8. If byte high enable (BHE) is LOW, then
data from memory will appear on I/O9 to I/O16. See the truth
table at the back of this datasheet for a complete description
of read and write modes.
The input/output pins (I/O1 through I/O16) are placed in a
high-impedance state when the device is deselected (CE
HIGH), the outputs are disabled (OE HIGH), the BHE and BLE
are disabled (BHE, BLE HIGH), or during a write operation (CE
LOW, and WE LOW).
The CY7C1021 is available in standard 44-pin TSOP Type II
and 400-mil-wide SOJ packages.
