MAX9830,pdf datasheet (Class D
消耗积分:3 | 格式:rar | 大小:322 | 2009-08-21
王磊
分享资料个
The MAX9830 mono 2W Class D amplifier provides Class AB audio performance with Class D efficiency.
Active emissions limiting edge rate and overshoot control circuitry greatly reduces EMI. A patented filterless spread-spectrum modulation scheme eliminates the need for output filtering found in traditional Class D devices. These features reduce application component count.
The MAX9830’s industry-leading 1.6mA at 5V, 1.2mA at 3.6V quiescent current extends battery life in portable applications.
The MAX9830 is available in an 8-pin TDFN (2mm x 2mm x 0.8mm) and is specified over the extended -40°:C to +85deg:C temperature range.
评论(0)
发评论
下载排行榜
