AD8214,pdf datasheet(common-mode voltage threshold detector)
消耗积分:3 | 格式:rar | 大小:404 | 2009-08-25
吴湛
分享资料个
The AD8214 is a fast, high common-mode voltage threshold detector, which operates with a single supply of 5 V to 65 V. Internally the AD8214 features a fast comparator that is optimized for high side operation. It also includes a stable 2.4 V series regulator, which is referenced with respect to the supply voltage. The purpose of the regulator is to provide power to the internal electronics, and set an input comparison threshold below the supply voltage. The inputs of the AD8214 may be operated at, slightly above, or below the power supply. The differential voltage range between the inputs of the AD8214 is 500 mV.
The device features a current output. This current is <100 nA when –IN > +IN and 1 mA when +IN > –IN. The input
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
