AD8306,pdf datasheet (Limiting-Logarithmic Amplifier)
消耗积分:5 | 格式:rar | 大小:397 | 2009-08-27
世态薄凉
分享资料个
low frequency applications, a simple RC network forming a lowpass
filter should be added at the input for the same reason.
If the limiter output is not required, Pin 9 (LMDR) should be
left open and Pins 12 and 13 (LMHI, LMLO) should be tied to
VPS2 as shown in Figure 24.
Figure 25 shows the output versus the input level in dBV, for
sine inputs at 10 MHz, 50 MHz and 100 MHz (add 13 to the
dBV number to get dBm Re 50 W. Figure 26 shows the typical
logarithmic linearity (log conformance) under the same
conditions.
评论(0)
发评论
下载排行榜
