SIMPLE SWITCHER PCB Layout Guide
消耗积分:0 | 格式:pdf | 大小:229KB | 2016-10-16
422758047
分享资料个
One problem with writing an Application Note on PCB layout is that the people who read it are usually not the ones who are going to use it. Even if the designer has struggled through electromagnetic fields, EMC, EMI, board parasitics, transmission line effects, grounding, etc., he will in all probability then go on with his primary design task, leaving the layout to the CAD/layout person.
评论(0)
发评论
下载排行榜
