The ADA4627-1 is a wide bandwidth, high precision, JFET input amplifier from ADI’s Advanced Bipolar Trench Isolated Process, iPOLAR. These amplifiers have low offset, drift, and bias current. Operation is fully specified from 8 V to 36 V single supply (±8 V to ±18 V dual supply).
The ADA4627-1offers better AC performance compared to the OPA627, higher slew rate, higher bandwidth, and better capacitive load drive capability.
These op amps are ideal for various applications including precision instrumentation and measurement systems, process active filtering, data conversion, buffering, and high impedance sensor frontends.
Two grades are offered with the ADA4627-1B-grade with tighter offset performance over extended industrial temperature.
The ADA4627-1A-grade is specified for the industrial temperature range (−40°C to +85°C).
The ADA4627-1B-grade is specified for the extended industrial temperature range (−40°C to +125°C).
Both grade of AD4627-1 is available in 8-lead SOIC and 8-lead LFCSP (3x2) packages.
