AD558,pdf datasheet (P-Compati
消耗积分:5 | 格式:rar | 大小:541 | 2009-09-17
分享资料个
The AD558 consists of four major functional blocks, fabricated
on a single monolithic chip (see Figure 2). The main D-to-A
converter section uses eight equally-weighted laser-trimmed
current sources switched into a silicon-chromium thin-film
R/2R resistor ladder network to give a direct but unbuffered 0
mV to 400 mV output range. The transistors that form the
DAC switches are PNPs; this allows direct positive-voltage logic
interface and a zero-based output range.
评论(0)
发评论
下载排行榜
