AD8305,pdf datasheet (Logarith
消耗积分:5 | 格式:rar | 大小:503 | 2009-09-23
张生
分享资料个
The AD8305 is an inexpensive microminiature logarithmic
converter optimized for determining optical power in fiber optic
systems. It uses an advanced implementation of a classic translinear
(junction based) technique to provide a large dynamic
range in a versatile and easily used form. A single-supply voltage of
between 3 V and 12 V is adequate; dual supplies may optionally
be used. The low quiescent current (typically 5 mA) permits use
in battery-operated applications.
评论(0)
发评论
下载排行榜
