LM5102,pdf datasheet (High Vol
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-06
贾虎世
分享资料个
The LM5102 High Voltage Gate Driver is designed to drive
both the high side and the low side N-Channel MOSFETs in
a synchronous buck or a half bridge configuration. The floating
high-side driver is capable of working with supply voltages
up to 100V. The outputs are independently controlled.
The rising edge of each output can be independently delayed
with a programming resistor. An integrated high voltage
diode is provided to charge the high side gate drive
bootstrap capacitor. A robust level shifter operates at high
speed while consuming low power and providing clean level
transitions from control logic to the high side gate driver.
Under-voltage lockout is provided on both the low side and
the high side power rails. This device is available in the
standard MSOP-10 pin and the LLP-10 pin packages.
评论(0)
发评论
下载排行榜
