相控阵天线波束控制的基本原理和波控系统的任务
消耗积分:10 | 格式:rar | 大小:444 | 2009-10-06
贾飞小
分享资料个
基于相控阵天线波束控制的基本原理和波控系统的任务,讨论了相控阵雷达波控系
统的相关问题。通过MATLAB 仿真可知,依据相控阵天线雷达的方向图的可分离性,实现了对雷达波束的控制,本文采用分布式查表和程序运算相结合的方法,提高了波控运算速度。
关键词:相控阵天线; 波束控制; 仿真
Abstract: Based on the theory of beam steering of phase array antenna and the task of beam
steering system, discussed the interrelated problems of beam steering system of phase array
antenna. Simulated by MATLAB, it carried out controlling to radars’ beam according to the
pattern’s separation of the phase array radar. The method of this paper is the combination of
distributed seeking table and procedure operation, enhancing the speed of beam-control operation.
Keyword: Phased array antenna; Beam steering; Simulation
评论(0)
发评论
下载排行榜
