DS90C032,pdf datasheet (LVDS Q
消耗积分:3 | 格式:rar | 大小:555 | 2009-10-13
分享资料个
TheDS90C032 is a quad CMOS differential line receiver designed
for applications requiring ultra low power dissipation
and high data rates. The device is designed to support data
rates in excess of 155.5 Mbps (77.7 MHz) utilizing Low Voltage
Differential Signaling (LVDS) technology.
TheDS90C032 accepts low voltage (350 mV) differential input
signals and translates them to CMOS (TTL compatible)
output levels. The receiver supports a TRI-STATE® function
that may be used to multiplex outputs. The receiver also supports
OPEN, shorted and terminated (100Ω) input Failsafe
with the addition of external failsafe biasing. Receiver output
will be HIGH for both Failsafe conditions.
TheDS90C032 and companion line driver (DS90C031) provide
a new alternative to high power psuedo-ECL devices for
high speed point-to-point interface applications.
评论(0)
发评论
下载排行榜
