DS99R101/DS99R102,pdf datashee
消耗积分:3 | 格式:rar | 大小:556 | 2009-10-14
安立路
分享资料个
The DS99R101/DS99R102 Chipset translates a 24-bit parallel
bus into a fully transparent data/control LVDS serial stream
with embedded clock information. This single serial stream
simplifies transferring a 24-bit bus over PCB traces and cable
by eliminating the skew problems between parallel data and
clock paths. It saves system cost by narrowing data paths that
in turn reduce PCB layers, cable width, and connector size
and pins.
评论(0)
发评论
下载排行榜
