74LVC4066 pdf datasheet
消耗积分:3 | 格式:rar | 大小:444 | 2008-07-14
微风挽雨
分享资料个
The 74LVC4066 is a high-speed Si-gate CMOS device.
The 74LVC4066 provides four single pole, single-throw analog switch functions. Each
switch has two input/output terminals (nY and nZ) and an active HIGH enable input (nE).
When nE is LOW, the analog switch is turned off.
Schmitt-trigger action at the enable inputs makes the circuit tolerant of slower input rise
and fall times across the entire VCC range from 1.65 V to 5.5 V.
评论(0)
发评论
下载排行榜
