74HC4852 pdf datasheet
消耗积分:5 | 格式:rar | 大小:444 | 2008-07-14
分享资料个
The 74HC4852 is a high-speed Si-gate CMOS device and is specified in compliance with
JEDEC standard no. 7A.
The 74HC4852 is a dual 4-channel analog multiplexer or demultiplexer with common
select inputs (S0 and S1). Both multiplexers have a common active LOW enable input (E),
four independent inputs/outputs (pins nY0 to nY3) and a common input/output (pin nZ).
The device features injection-current effect control, which has excellent value in
automotive applications where voltages in excess of the supply voltage are common.
With E LOW, two of the eight switches are selected (low impedance ON-state) by S0 and
S1. With E HIGH, all switches are in the high-impedance OFF-state, independent of S0
and S1.
The injection-current effect control allows signals at disabled analog input channels to
exceed the supply voltage without affecting the signal of the enabled analog channel. This
eliminates the need for external diode/resistor networks typically used to keep the analog
channel signals within the supply-voltage range.
评论(0)
发评论
下载排行榜
