FEATURES • Requires very few external components • No switch-on/switch-off clicks • Input mute during switch-on and switch-off • Low offset voltage between output and ground • Hi-fi in accordance with IEC 268 and DIN 45500 • Short-circuit proof and thermal protected • Mute possibility. GENERAL DESCRIPTION The TDA2614 is a power amplifier in a 9-lead single-in-line (SIL9) plastic medium power package. It has been especially designed for mains fed applications, such as TV and radio.
