TDA2616/TDA2616Q pdf datasheet
消耗积分:10 | 格式:rar | 大小:777 | 2008-07-15
分享资料个
FEATURES
• Requires very few external components
• No switch-on/switch-off clicks
• Input mute during switch-on and switch-off
• Low offset voltage between output and ground
• Excellent gain balance of both amplifiers
• Hi-fi in accordance with IEC 268 and DIN 45500
• Short-circuit proof and thermal protected
• Mute possibility.
GENERAL DESCRIPTION
The TDA2616 and TDA2616Q are dual power amplifiers.
The TDA2616 is supplied in a 9-lead single-in-line (SIL9)
plastic power package (SOT131), while the TDA2616Q is
supplied in a 9-lead SIL-bent-to-DIL plastic power package
(SOT157). They have been especially designed for mains
fed applications, such as stereo radio and stereo TV.
评论(0)
发评论
下载排行榜
