AD9834,pdf datasheet (20 mW Po
消耗积分:5 | 格式:rar | 大小:554 | 2009-10-24
33391
分享资料个
The AD9834 is a 75 MHz low power DDS device capable of producing high performance sine and triangular outputs. It also has an on-board comparator that allows a square wave to be produced for clock generation. Consuming only 20 mW of power at 3 V makes the AD9834 an ideal candidate for power-sensitive applications.
评论(1)
发评论
xingyueleiwuhen 2011-08-16
3 回复 举报
貌似看过这个了 收起回复
下载排行榜
全部1条评论
