The ADG611, ADG612, and ADG613 are monolithic CMOS
devices containing four independently selectable switches. These
switches offer ultralow charge injection of 1 pC over full input
signal range and typical leakage currents of 10 pA at 25°C.
They are fully specified for ±5 V, +5 V, and +3 V supplies.
They contain four independent single-pole/single-throw (SPST)
switches. The ADG611 and ADG612 differ only in that the
digital control logic is inverted. The ADG611 switches are turned
on with a logic low on the appropriate control input, while a logic
high is required to turn on the switches of the ADG612. The
ADG613 contains two switches whose digital control logic is
similar to the ADG611, while the logic is inverted on the other
two switches.
