智能驱动控制LED温度,解决SSL热问题
随着大功率LED技术的成熟,工程师们收集了数据,定量地证实了过多的热量缩短了固态照明(SSL)的寿命。例如,一个LED,持续60000小时,而在交界处的温度为120°C挣扎发光超过10000小时,当工作在150°C,因此,热管理迅速成为SSL设计过程中的一个重要组成部分。
设计师通常使用被动技术来散热。在正常操作,这种方法工作得很好,但可以挣扎散热的SSL暴露在异常温暖的温度下时,所有的热量。
Recently, LED power supply (LED driver) makers have added current-limiting capabilities to their devices allowing engineers to determine LED-junction temperature and turn down the wick if things get too hot. Over-temperature protection extends LED life and minimizes catastrophic failure. Active protection methods also encourage the use of smaller heatsinks––saving cost and space––and offer a greater degree of control over the maximum operating temperature of a particular product. This article takes a look at how these newer thermal-management techniques work.
