ABSTRACT
The PCM9211 evaluation module (EVM) is designed to allow users to record and play back audio signals via a USB interface while running CodecControl software on a PC. The USB interface uses the TAS1020B USB interface device. This document presents a detailed description of the recording interface setup from an analog input to PC, and discusses how to play back a digital signal from the PC via a USB connection. In both cases, the path and the clock settings are enabled using the CodecControl software. Hardware setup and jumper configurations are also described.
