Using the P82B96 for bus inter
消耗积分:3 | 格式:rar | 大小:224 | 2009-11-03
tr12345
分享资料个
The P82B96 offers many different ways in which it can be used as a
bus interface. In its simplest application it can be used as an
interface between bus systems operating from different supply
voltages. Opto isolation between two bus systems is possible, and
also the availability of the Tx and Rx signals permits interfacing of
the P82B96 with other bus systems which separate the forward
output path, from the backward input signal path.
评论(0)
发评论
下载排行榜
