3.3V单通道视频驱动器重建滤波器和凹陷矫正NCS2561SQT1G
消耗积分:0 | 格式:rar | 大小:0.46 MB | 2017-09-07
分享资料个
  The NCS2561 is a single high speed video driver including a 2−pole reconstruction filter and SAG correction capability. The NCS2561 is available in a space saving SC−88 package optimized for low voltage, portable applications. It is designed to be compatible with Digital−to−Analog Converters (DAC) embedded in most video processors. The NCS2561 internally integrates an 8 MHz 2−pole video DAC reconstruction filter with a fixed gain of 2. The NCS2561 also has a built−in SAG correction circuit when used at the output in an AC−coupled mode. To further reduce power consumption, an enable pin is provided
评论(0)
发评论
下载排行榜
