2A 23V 400kHz Synchronous Rect
消耗积分:3 | 格式:rar | 大小:225 | 2009-12-03
贾大林
分享资料个
The CYT3482 is a monolithic synchronous buck regulator. The device integrates 100mΩ MOSFETS that provide 2A continuous load cur-rent over a wide operating input voltage of 4.75V to 23V. Current mode control provides fast ransient response and cycle-by-cycle
cur-rent limit. An adjustable soft-start prevents inrush current at turn-on. In shutdown mode, the supply cur-rent drops below 1 μA. This device, available in an 8-pin SOIC pack-age, provides a very compact system solution with minimal reliance on external components.
评论(0)
发评论
下载排行榜
