The AD9548 provides synchronization for many systems, including synchronous optical networks (SONET/SDH)。 The AD9548 generates an output clock synchronized to one of up to four differential or eight single-ended external input references. The digital PLL allows for reduction of input time jitter or phase noise associated with the external references. The AD9548 continuously generates a clean (low jitter), valid output clock even when all references have failed by means of a digitally controlled loop and holdover circuitry. The AD9548 operates over an industrial temperature range of −40°C to +85°C.
