The AD8183 (G = +1) and AD8185 (G = +2) are high speed triple 2:1 multiplexers. They offer –3 dB signal bandwidth up to 380 MHz, along with slew rate of 1000 V/μs. With better than –90 dB of channel-to-channel crosstalk and isolation at 10 MHz, they are useful in many high-speed applications. The differential gain and differential phase errors of 0.01% and 0.02° respectively, along with 0.1 dB flatness to 90 MHz make the AD8183 and AD8185 ideal for professional video and RGB multiplexing. They offer 15 ns channel-to-channel switching time, making them an excellent choice for switching video signals, while consuming less than 25 mA on ±5 V supply voltages. Both devices offer a high speed disable feature that can set the output into a high impedance state. This allows the building of larger input arrays while minimizing “OFF” channel output loading. They operate on voltage supplies of ±5 V and are offered in a 24-lead TSSOP package.
