74HC148 pdf datasheet
消耗积分:10 | 格式:rar | 大小:133 | 2008-08-06
分享资料个
MM54HC148/MM74HC148
8-3 Line Priority Encoder
General Description
This priority encoder utilizes advanced silicon-gate CMOS
technology. It has the high noise immunity and low power
consumption typical of CMOS circuits, as well as the speeds
and output drive similar to LB-TTL.
This priority encoder accepts 8 input request lines 0±7 and
outputs 3 lines A0±A2. The priority encoding ensures that
only the highest order data line is encoded. Cascading circuitry
(enable input EI and enable output EO) has been provided
to allow octal expansion without the need for external
circuitry. All data inputs and outputs are active at the low
logic level.
All inputs are protected from damage due to static discharge
by internal diode clamps to VCC and ground.
Features
Y Typical propagation delay: 13 ns
Y Wide supply voltage range: 2V±6V
评论(0)
发评论
下载排行榜
