AT101X是一款由一个GaAs发光二极管和一个NPN光电晶体管组成的光电耦合器
消耗积分:0 | 格式:pdf | 大小:1.31 MB | 2025-02-18
腾震粤电子
  • 337内容
  • 42w+阅读
  • 581粉丝
概述 Description
AT101X是一款由一个GaAs发光二极管和一个NPN光电晶体管组成的光电耦合器。
The AT101X is a photoelectric coupler composed of a GaAs light-emitting diode and a NPN photo transistor.
特性 Features
电流转换比(CTR)范围: ≥80% (I F =5mA, V CE =5V, Ta=25℃)
Current transfer ratio: ≥80% (I =5mA, V =5V, Ta=25℃)
F CE
输入-输出隔离电压 (V ISO =5000 Vrms )
High isolation voltage between input and output(V ISO =5000 Vrms )
集电极-发射极击穿电压 BV CEO ≥80V
Collector - emitter breakdown voltage BV CEO ≥80V
工作温度:-55℃~110℃
Operating Temperature: -55℃~110℃
符合加强绝缘标准
Meet reinforced insulation standards
符合安规标准:UL 1577,VDE DIN EN60747-5-5 (VDE 0884-5),CQC11-471543-2022
Safety standards approval: UL 1577, VDE DIN EN60747-5-5 (VDE 0884-5),CQC11-471543-2022
应用 Applications
开关电源,智能电表
Switching power supply, intelligent meter
工业控制,测量仪器
Industrial control, measuring instruments
办公设备, 比如复印机
Office equipment such as copiers
家用电器, 比如空调、风扇、热水器等
Household appliances: such as air conditioners, fans, water heaters, etc
评论(0)
发评论
下载排行榜
