AAT4610B,pdf datasheet(Current
消耗积分:3 | 格式:rar | 大小:221 | 2010-01-29
张杰
分享资料个
The AAT4610B SmartSwitch is a current limited P-channel MOSFET power switch designed for high-side load switching applications. This switch operates with inputs ranging from 2.4V to 5.5V, making it ideal for both 3V and 5V systems. An integrated current-limiting circuit
protects the input supply against large currents which may cause the supply to fall out of regulation. The AAT4610B is also protected from thermal overload which limits power dissipation and junction temperatures. It can be used to control loads that require up to 1A.
Current limit threshold is programmed with a resistor from SET to ground. The quiescent supply current istypically a low 9μA. In shutdown mode, the supply current decreases to less than 1μA.
评论(0)
发评论
下载排行榜
