AAT4670,pdf datasheet(Dual-Inp
消耗积分:5 | 格式:rar | 大小:221 | 2010-01-29
李勇
分享资料个
The AAT4670 SmartSwitch is a member of AnalogicTech’s Application Specific Power MOSFET ™ (ASPM™) product family. The AAT4670 consists of dual, independent, 1A current limited, slew rate controlled P-channel MOSFET power switches with a dedicated source and drain pin assigned to each switch. The internal circuitry automatically
derives power from the higher of the two input power source pins with a low operating quiescent current of 18μA. In shutdown mode, the supply current decreases to less than 1μA. The switches operate with inputs ranging from 2.2V to 5.5V, making them ideal for 2.5V, 3V, and 5V systems. The dual configuration permits integration of the load switch function for systems with two different power busses. Independent under-voltage lockout circuits
will shut down the corresponding switch if its input voltage falls below the under-voltage lockout threshold. If the die temperature reaches the thermal limit, both switches thermal cycle off and on indefinitely without damage until the thermal condition is removed. An open drain FAULT output signals an
over-current or over-temperature condition for each
channel. Input logic levels are TTL compatible.
评论(0)
发评论
下载排行榜
