General Description The TC1034/TC1035 are single CMOS operational amplifiers for low power applications. They have a typical operating supply current of 6μA, which is constant over the supply voltage range of 1.8V to 5.5V. The Op Amp has a rail-to-rail input and output which allows operation at low supply voltages with large input and output signal swings. An active low shutdown input, SHDN, is available on the TC1035 and disables the op amp, placing its output in a high-impedance state. The TC1035 draws less than 0.1μA when the shutdown mode is active. Packaged in a 5-Pin SOT-23A (TC1034) or 6-Pin SOT- 23A (TC1035), these single operational amplifiers are ideal for applications requiring high integration, small size and low power.
