AAT3142,pdf datasheet(High Eff
消耗积分:2 | 格式:rar | 大小:221 | 2010-01-30
贾大林
分享资料个
The AAT3142 is a low noise, constant frequency charge pump DC/DC converter that uses a tri-mode load switch (1X), fractional (1.5X), and doubling (2X) conversion to maximize efficiency for white LED applications. The device produces current levels up to 30mA on each of its three current source outputs to drive various arrangements of LEDs from a 2.7V to 5.5V input. Outputs may be operated individually or in parallel for driving highercurrent LEDs. A low external parts count (two 1μF flyingcapacitors and two small 1μF capacitors at VIN and CP) make the AAT3142 ideally suited for small battery-powered applications.
评论(0)
发评论
下载排行榜
