24C08B/24C16B pdf datasheet
消耗积分:5 | 格式:rar | 大小:555 | 2008-08-07
fansz
分享资料个
The Microchip Technology Inc. 24C08B/16B is an 8K or
16K bit Electrically Erasable PROM intended for use in
extended/automotive temperature ranges. The device
is organized as four or eight blocks of 256 x 8-bit memory
with a 2-wire serial interface. The 24C08B/16B also
has a page-write capability for up to 16 bytes of data.
The 24C08B/16B is available in the standard 8-pin DIP
and both 8-lead and 14-lead surface mount SOIC packages.
评论(0)
发评论
下载排行榜
