MAX3784, MAX3784A,pdf,datashee
消耗积分:5 | 格式:rar | 大小:233 | 2010-03-04
KANA
分享资料个
The MAX3784/MAX3784A 5Gbps equalizers provide
compensation for transmission-medium losses in up to
40in of FR-4. They are optimized for short-run length
and balanced codes such as 8b10b, as found in multiplexed
1.25Gbps Ethernet systems and 4.25Gbps
Fibre Channel.
The equalizers use differential CML data inputs and
outputs. A standby mode reduces power consumption
when the parts are not in use. The MAX3784/
MAX3784A are available in a 4mm × 4mm, 16-pin QFN
package that consumes only 185mW at +3.3V.
评论(0)
发评论
下载排行榜
