磁记忆检测在无缝钢轨内应力测试中的可行性研究
消耗积分:3 | 格式:rar | 大小:145 | 2010-03-20
分享资料个
使用TSC21M24 型应力集中磁指示仪测量在不同载荷下钢轨表面磁场强度的变化,得出钢
轨的磁场强度随载荷的增加而逐渐增大,且在弹性范围内,磁场强度和载荷为近似线性关系。提出金属磁记忆法可以对钢轨内应力进行定量测量。
The facial magnetic st rength of railway was tested using magnetic indictor TSC21M24
at differentloads. Experimental data showed the magnetic st rength increased with load and it s
relation with load was linearwithin elastic deformation. Therefore metal magnetic memory testing ( MMT) equipment s could be used inmeasuring internal st ress of seamless railway.
评论(0)
发评论
下载排行榜
