NCL30000 pdf,detasheet
The NCL30000 is a switch mode power supply controller intended
for low to medium power single stage power factor (PF) corrected
LED Drivers. The device is designed to operate in critical conduction
mode (CrM) and is suitable for flyback as well as buck topologies.
Constant on time CrM operation is particularly suited for isolated
flyback LED applications as the control scheme is straightforward and
very high efficiency can be achieved even at low power levels.
