MAX8893 pdf,datasheet
消耗积分:5 | 格式:rar | 大小:2386 | 2010-05-29
84784
分享资料个
The MAX8893 evaluation kit (EV kit) is a fully assembled
and tested PCB that demonstrates the highly integrated
MAX8893C power-management IC. The MAX8893 EV kit
operates from a 2.7V to 5.5V input supply range and is
controlled by an I2C interface. The MAX8893C integrates
a high-efficiency step-down DC-DC converter, five lowdropout
(LDO) linear regulators with programmable
output voltages, individual power on/off control inputs,
a load switch, and a USB high-speed switch. The I2C
interface controls all the regulator output voltages, load
switch timing, individual enable/disable control, and
other parameters.
评论(0)
发评论
下载排行榜
