The TALP1000B is a high performance micromirror designed for use in multiple light steering applications. The large 2-axis micromirror is constructed of single crystal silicon, which has no grain boundaries and is virtually defect free. This produces a hinge with no work hardening and gives the TALP1000B superior reliability characteristics. The gold coated optically active surface of the TALP1000B provides excellent reflectivity in the 700 nm to 10 um wavelength range. The mirror ’ s large size, large radius of curvature and high reflectivity make it easy to incorporate into many optical designs.
