Determining Minimum Acquisitio
消耗积分:3 | 格式:rar | 大小:330 | 2010-06-01
分享资料个
This application report analyzes a simple method for calculating minimum acquisition times for
successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the  ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined  for the case when a step function is applied to the input of the driving circuit. Three different test cases are subsequently evaluated using both precise and approximated equations.
评论(0)
发评论
下载排行榜
