PCM3500,pdf(Low Voltage, Low P
消耗积分:5 | 格式:rar | 大小:395 | 2010-06-23
分享资料个
The PCM3500 is a low cost, 16-bit CODEC designed for modem Analog Front End (AFE) and speech processing applications. The PCM3500’s low power operation from +2.7V to +3.6V power supplies, along with an integrated power-down mode, make it ideal for
portable applications.
The PCM3500 integrates all of the functions needed for a modem or voice CODEC, including delta-sigma The PCM3500 is a low cost, 16-bit CODEC designed for modem Analog Front End (AFE) and speech processing applications. The PCM3500’s low power operation from +2.7V to +3.6V power supplies, along with an integrated power-down mode, make it ideal for
portable applications. The PCM3500 integrates all of the functions needed for a modem or voice CODEC, including delta-sigma
评论(0)
发评论
下载排行榜
