The various versions of the TDA837x series are I2C-bus controlled single-chip TV processors which are intended to be applied in PAL/NTSC (TDA8374 and TDA8375) and NTSC (TDA8373 and TDA8377) television receivers. All ICs are available in an SDIP56 package and some versions are also available in a QFP64 package. The ICs are pin compatible so that with one application board NTSC and PAL/NTSC (or multistandard together with the SECAM decoder TDA8395) receivers can be built. Functionally this IC series is split in to 2 categories: · Versions intended to be used in economy TV receivers with all basic functions · Versions with additional functions such as E-W geometry control, horizontal and vertical zoom function and YUV interface which are intended for TV receivers with 110° picture tubes. The various type numbers are given in Table 1. The detailed differences between the various ICs are given in Table 2.
