TRF1216,pdf(3.5-GHz High Dynam
消耗积分:2 | 格式:rar | 大小:646 | 2010-07-06
370217
分享资料个
The TRF1216 is the first of two integrated circuits used in the receiver section of Texas Instruments’ 3.5-GHz radio chipset. The TRF1216 down-converts the 3.5-GHz input frequency to an intermediate frequency in the range of 400 MHz to 500 MHz. The device provides a differential output that passes through a SAW filter before connecting to a second down converter. For the best performance, Texas Instruments TRF1212 should be used to perform both the second down conversion and also provide the local oscillator for the TRF1216.
The TRF1216 includes a LNA with switchable attenuation, a balanced mixer, a variable gain IF amplifier and a differential LO Buffer for improved performance. In order to provide exceptional image rejection and extra jammer immunity, the TRF1216 offers a signal path to an off-chip filter.
评论(0)
发评论
下载排行榜
