SN54AHC16541, SN74AHC16541,pdf
消耗积分:2 | 格式:rar | 大小:380 | 2010-07-16
杨福林
分享资料个
The 'AHC16541 devices are noninverting 16-bit buffers composed of two 8-bit sections with separate output-enable signals. For either 8-bit buffer section, the two output-enable (1OE1\ and 1OE2\ or 2OE1\ and 2OE2\) inputs must be low for the corresponding Y outputs to be active. If either output-enable input is high, the outputs of that 8-bit buffer section are in the high-impedance state.
To ensure the high-impedance state during power up or power down, OE\ should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
The SN54AHC16541 is characterized for operation over the full military temperature range of -55°C to 125°C.
评论(0)
发评论
下载排行榜
