SN74ALVCH16344,pdf(1-BIT TO 4-
消耗积分:2 | 格式:rar | 大小:314 | 2010-07-16
维生素B2
分享资料个
This 1-bit to 4-bit address driver is designed for 1.65-V to 3.6-V VCC operation.
The SN74ALVCH16344 is used in applications in which four separate memory locations must be addressed by a single address.
To ensure the high-impedance state during power up or power down, OE\ should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver.
Active bus-hold circuitry holds unused or undriven inputs at a valid logic state. Use of pullup or pulldown resistors with the bus-hold circuitry is not recommended.
评论(0)
发评论
下载排行榜
