An efficient use of power is required to transmit data from the BTS to a mobile phone: •The transmission line system must be free of defects. •Each transmission line imperfection, every connection, and the antenna itself will reflect some of the generated power back toward the source. •Any reflected power will be absorbed by the transmission line system and source – this is an inefficient use of power. •The integrity of the transmission line system including the antenna must be tested.
