NCP1653, pdf,NCP1653A datashee
消耗积分:10 | 格式:rar | 大小:555 | 2008-09-06
向日葵的花季
分享资料个
NCP1653, NCP1653A Compact, Fixed−Frequency,Continuous Conduction
Mode PFC Controller
The NCP1653 is a controller designed for Continuous Conduction
Mode (CCM) Power Factor Correction (PFC) boost circuits. It
operates in the follower boost or constant output voltage in 67 or 100
kHz fixed switching frequency. Follower boost offers the benefits of
reduction of output voltage and hence reduction in the size and cost
of the inductor and power switch. Housed in a DIP−8 or SO−8
package, the circuit minimizes the number of external components
and drastically simplifies the CCM PFC implementation. It also
integrates high safety protection features. The NCP1653 is a driver
for robust and compact PFC stages.
Features
• IEC1000−3−2 Compliant
• Continuous Conduction Mode
• Average Current−Mode or Peak Current−Mode Operation
• Constant Output Voltage or Follower Boost Operation
• Very Few External Components
• Fixed Switching Frequency: 67 kHz = NCP1653A,
Fixed Switching Frequency: 100 kHz = NCP1653
• Soft−Start Capability
• VCC Undervoltage Lockout with Hysteresis (8.7 / 13.25 V)
• Overvoltage Protection (107% of Nominal Output Level)
• Undervoltage Protection or Shutdown (8% of Nominal Output Level)
• Programmable Overcurrent Protection
• Programmable Overpower Limitation
• Thermal Shutdown with Hysteresis (120 / 150C)
• Pb−Free Packages are Available
Typical Applications
• TV & Monitors
• PC Desktop SMPS
• AC Adapters SMPS
• White Goods
评论(0)
发评论
下载排行榜
