TCA8418,pdf(Controlled Keypad
消耗积分:5 | 格式:rar | 大小:846 | 2010-08-08
贾永世
分享资料个
特性
  • Operating Power-Supply Voltage Range of 1.65 V to 3.6 V
  • Supports QWERTY Keypad Operation Plus GPIO Expansion
  • 18 GPIOs Can Be Configured into Eight Inputs and Ten Outputs to
    Support an 8 × 10 Keypad Array (80 Buttons)
  • ESD Protection Exceeds JESD 22 on all 18 GPIO Pins and non GPIO pins
    • 2000-V Human Body Model (A114-A)
    • 1000-V Charged Device Model (C101)
  • Low Standby (Idle) Current Consumption: 3 µA
  • Polling Current Drain 70 µA for One Key Pressed
  • 10 Byte FIFO to Store 10 Key Presses and Releases
  • Supports 1-MHz Fast Mode Plus I2C Bus
  • Open-Drain Active-Low Interrupt Output, Asserted when Key is
    Pressed and Key is Released
  • Minimum Debounce Time of 50 µs
  • Schmitt-Trigger Action Allows Slow Input Transition and
    Better Switching Noise Immunity at the SCL and SDA Inputs:
    Typical Vhys at 1.8 V is 0.18 V
  • Latch-Up Performance Exceeds 200 mA Per JESD 78, Class II
  • Very Small Packages
    • WCSP (YFP): 2 mm × 2 mm; 0.4 mm pitch
    • QFN (RTW): 4 mm × 4 mm; 0.5 mm pitch
  • APPLICATIONS
    • Smart Phones
    • PDAs
评论(0)
发评论
下载排行榜
