MAX5195 pdf,MAX5195 datasheet
消耗积分:3 | 格式:rar | 大小:888 | 2008-09-11
分享资料个
The MAX5195 is an advanced, 14-bit, 260Msps digitalto-
analog converter (DAC) designed to meet the
demanding performance requirements of signal synthesis
applications found in wireless base stations and
other communication systems. Operating from a single
5V supply, this DAC offers exceptional dynamic performance
such as 77dBc spurious-free dynamic range
(SFDR) at fOUT = 19.4MHz, while supporting update
rates beyond 260Msps.
The MAX5195 current-source array architecture supports
a full-scale current range of 10mA to 20mA, which
allows a differential output voltage swing between
0.5VP-P and 1VP-P.
The MAX5195 features an integrated 1.2V bandgap reference
and control amplifier to ensure high accuracy
and low-noise performance. Additionally, a separate
reference input pin allows the user to apply an external
reference source for optimum flexibility.
The digital and clock inputs of the MAX5195 are
designed for differential LVPECL-compatible voltage
levels.
The MAX5195 is available in a 48-lead QFN package
with exposed paddle and is specified for the extended
industrial temperature range (-40°C to +85°C).
Applications
Base Stations:
Single-/Multi-Carrier UMTS, GSM
LMDS, MMDS, Point-to-Point Microwave
Direct IF Synthesis
Digital-Signal Synthesis
Broadband Cable Systems
Automated Test Equipment
Instrumentation
评论(0)
发评论
下载排行榜
