Errata to TFP510 Data Sheet
消耗积分:2 | 格式:rar | 大小:195 | 2010-08-24
王磊
分享资料个
 1.  DE Generator:
The DE generator function has a limitation which limits its use in high pixel count formats.  The DE_DLY
and DE_CNT values are limited by DE_DLY + DE_CNT < 2047.
For resolutions where the timing allows, it may be possible to work around this limitation by using the
inactive edge of HSYNC as the starting point for DE_DLY.  Appropriate timing allowances may be needed
for the vertical count starting location.
评论(0)
发评论
下载排行榜
