AM26LV32,pdf(Low-voltage high-
消耗积分:3 | 格式:rar | 大小:624 | 2010-08-28
分享资料个
The AM26LV32, BiCMOS, quadruple, differential line receiver with 3-state outputs is designed to be similar to TIA/EIA-422-B and ITU Recommendation V.11 receivers with reduced common-mode voltage range due to reduced supply voltage.
The device is optimized for balanced bus transmission at switching rates up to 32 MHz. The enable function is common to all four receivers and offers a choice of active-high or active-low inputs. The 3-state outputs permit connection directly to a bus-organized system. Each device features receiver high input impedance and input hysteresis for increased noise immunity, and input sensitivity of ±200 mV over a common-mode input voltage range from -0.3 V to 5.5 V. When the inputs are open circuited, the outputs are in the high logic state.
评论(0)
发评论
下载排行榜
