TRS3232E,pdf(3-V TO 5.5-V MULT
消耗积分:2 | 格式:rar | 大小:544 | 2010-08-31
王飞云
分享资料个
特性
  • ESD Protection for RS-232 Bus Pins
    • ±15-kV Human Body Model (HBM)
    • ±8 kV (IEC61000-4-2, Contact Discharge)
    • ±15 kV (IEC61000-4-2, Air-Gap Discharge)
  • Meets or Exceeds the Requirements of TIA/EIA-232-F and ITU v.28 Standards
  • Operates With 3-V to 5.5-V VCC Supply
  • Operates up to 250 kbit/s
  • Two Drivers and Two Receivers
  • Low Supply Current . . . 300 µA Typ
  • External Capacitors . . . 4 × 0.1 µF
  • Accepts 5-V Logic Input With 3.3-V Supply
  • Pin Compatible to Alternative High-Speed Device (1 Mbit/s)
    • TRSF3232E
  • APPLICATIONS
    • Battery-Powered Systems
    • PDAs
    • Notebooks
    • Laptops
    • Palmtop PCs
    • Hand-Held Equipment
评论(0)
发评论
下载排行榜
